Discussion topic: No wifi
Message posted on 11 Apr 2026 03:43 PM
No wifi
No WiFi connection and yellow light on hub
Message posted on 11 Apr 2026 04:01 PM
Re: No wifi
@Christine4764
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
