Discussion topic: No wi fi
Message posted on 11 Apr 2026 02:48 PM
No wi fi
I have no wi fi. It was off yesterday too. I believe others in the area are also experiencing problems.
Message posted on 11 Apr 2026 02:52 PM
Re: No wi fi
@Jane226
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
