Discussion topic: No wifi
Message posted on 31 Jan 2026 10:20 AM
No wifi
Message posted on 31 Jan 2026 10:22 AM
Re: No wifi
@clair+hobbs
With any broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Message posted on 31 Jan 2026 10:27 AM
Re: No wifi
Message posted on 31 Jan 2026 10:28 AM
Re: No wifi
So have you tried the troubleshooting above?
