Discussion topic: No wifi
This message was authored by: Paige51
No wifi
Hi, Everything says the wifi etc is working fine on the tests. Yet I can’t use phones on wifi and tvs are not working on wifi. Help please
Re: No wifi
@Paige51
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
If that doesn't fix it then try running this line test to see if it finds any faults:
If this is of no help give Sky a call to report it to them.
