Discussion topic: No wifi
This message was authored by: Lm6111
Message posted on 21 Nov 2025 06:49 AM
No wifi
No WiFi connection from Sky Q box. Have tried all connections no good.
Find out more
Message posted on 21 Nov 2025 07:16 AM
Re: No wifi
@Lm6111 che k if other devices are connecting correctly if they arent check the lights on the Sky hubs see https://www.sky.com/help/articles/hub-lights-explained-start
If the hub is vonnected properly reboot the Q box by diconnecting the power which may sort the problem. If it doesn't post which colour Sky hub you have and whether this isca nain Sky box or a Sky Mini.
