Discussion topic: No wifi
This message was authored by: Tom318
No wifi
My internet is not working
Re: No wifi
@Tom318   First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Re: No wifi
@Tom318
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it)
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
