Discussion topic: Slow WIFI
This message was authored by: Michael544
Slow WIFI
WI-FI speed into the house averages just over 40 We gave fibre and should be receiving minimum 400. This has been going on for weeks.
This message was authored by: Sharcuk
Re: Slow WIFI
@Michael544
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your ISP (in this case Sky).
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Sky Q, 2 mini boxes, booster and full fibre gigafast. Good WiFi coverage throughout a 4-bedroom house!
