Discussion topic: No wifi
This message was authored by: RussellDavis
No wifi
Help, i have no wifi but all the tests say its working fine
Re: No wifi
@RussellDavis
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
