Discussion topic: No wifi
This message was authored by: Shosho
No wifi
Ran tests all day good but no WiFi at all
Re: No wifi
@Shosho
If a reboot of your broadband hub at the mains doesn't bring things back to life then try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
Avatar for Shosho
Re: No wifi
Reported to sky, did all diagnostics, only 2 green lights showing on hub, they've contacted outreach and said could take up till the 22/07/25 to be fixed.. summer holidays have just started 😩
Re: No wifi
@Shosho
It is Openreach, not Outreach.
The service level agreement in the UK between ISP’s and Openreach for fixing a fault is 2 WORKING DAYS which is the usual quoted time as Openreach claim to fix faults within that timeframe in 85+% of cases. That, for you is the 22nd.
This link explains the Ofcom agreed auto compensation scheme which Sky operates for when there is a TOTAL loss of Sky Broadband or Sky Talk for UK customers.
https://www.sky.com/help/articles/auto-compensation
If you have a total loss of service and it isn’t fixed after two full WORKING days from when Sky are notified of the fault, you will become eligible for it.
From Ofcom’s website:~
If your broadband or landline service stops working, you will have to report the fault to your provider. If the service is not fixed after two full working days, you would not need to ask for compensation or contact your provider again, as your provider has systems in place that mean you will start receiving compensation automatically if the repair takes too long.
This auto compensation is applied 30 days after the fault has been repaired and will come in the form of a credit appearing on your Sky account (from 01/04/25 the new rates are £9.98 per day). There is no equivalent scheme in place for customers in the Republic of Ireland.
As Sky broadband discussed here is a domestic set up there is no extra or quicker support for those working from home.
