Discussion topic: Wifi Coverage
This message was authored by: Mick174
Wifi Coverage
Hello, since I have gone over to Sky from BT the Wifi signal coverage in my house is alot weaker
This message was authored by: Leroyuk1983
Re: Wifi Coverage
I am having the exact same issue, with BT i could get a strong signal in every room, with Sky BB Max im lucky if i get two bars, even in the same room as the hub. Eveything is setup in the same position too with enough space around them.
Trying to find a way to contact Sky  (other than phone) is rediculous, the robot assistant is useless.
