Discussion topic: No wifi
This message was authored by: Ln45
No wifi
Please help I have done all the troubleshoot but says I have no internet
Re: No wifi
@Ln45 What do you see on the hub! link below about hub and lights.
Avatar for Ln45
Re: No wifi
The internet part is just blank so it's the internet connection that is the problem
Re: No wifi
@Ln45 Run the service checker to see if it can find anything area specific. Again link is below!
Re: No wifi
@Ln45 Going to take it that you have the Sky Broadband Hub from the first link with the Internet led that is out!
Avatar for Ln45
Re: No wifi
Yes that is correct
Re: No wifi
Hi @Ln45
I have escalated your post to Sky, look out for a message on the forum
I am NOT a Sky Employee
This message was authored by: Addie15
Re: No wifi
Hi there! Thank you for escalating this. We have sent an invite to @Ln45.
