Discussion topic: No wifi
This message was authored by: Claire030182
No wifi
No WiFi, but online tests are saying its fine
Re: No wifi
@Claire030182
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
For a broadband issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
