Discussion topic: No wifi
Message posted on 15 May 2025 03:11 PM
No wifi
Wifi not working
Message posted on 15 May 2025 03:16 PM
Re: No wifi
@Rob307 wrote:
Wifi not working
@Rob307
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If it's a broadband issue and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Message posted on 15 May 2025 03:17 PM
Re: No wifi
@Rob307 Are you talking about your broadband is not working if that is the case what colour are the lights on your router just now?
