Discussion topic: No wifi
This message was authored by: Nicola1510
No wifi
Hi my wifi has all of the sudden disconnected. No lights on anything. I'm working from home and need this urgently back up and running. Thanks
This message was authored by: Glaw1986
Re: No wifi
Mine has dropped too yet the broadband check is stating there are no issues ! The mind boggles
This message was authored by: 20Em
Re: No wifi
Mine is the same!
Re: No wifi
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
