Discussion topic: No wifi
This message was authored by: Keith789
No wifi
I unplugged my router to move location and once re connected I no longer have wifi
Re: No wifi
@Keith789 do you really mean wifi signal from the hub or the hub has not connected to the line check the lights onnthe hub (see https://www.sky.com/help/articles/hub-lights-explained-start)
If the hub is nonconnecting check the cable from the telephone socket or ONT is properly plugged in. If youb are trying to use a different phone socket it could well be due to that socket nit supporting broadband.
