Discussion topic: Wifi
Message posted on 08 Apr 2025 03:58 PM
Wifi
Message posted on 08 Apr 2025 04:04 PM
Re: Wifi
@Jacqui66
Wi-Fi is the connection between devices and your router. Broadband is the internet connection provided by your ISP to your dwelling.
