Discussion topic: No wifi
This message was authored by: Andy+Boyle
No wifi
No WiFi. Reset router but no fix
Re: No wifi
@Andy+Boyle
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
This message was authored by: Joan+Burst
Re: No wifi
Same here.  Openreach out today and text just received saying it's fixed bit still no broadband or phone line!
This message was authored by: RW6
Re: No wifi
Same here. No problems reported by service checker, or any issues being reported in the area. Have internet on wired devices but no Wi-Fi is being broadcast on router so nothing for mobile devices to connect to.
Re: No wifi
So looked on another forum post that said to try holding the wps button for 30 seconds (was 45 for me) till light flashes green. Waited 5 or so mins and wired connection came back then after another 5/10 mins Wi-Fi signal popped back up... could have been a coincidence and whatever problem was fixed or could have been the 'reset'.
Re: No wifi
My WiFi and power lights are green but internet isn't showing anything.  Have tried the wpa button so will leave it and keep my fingers crossed that it resets everything.  Failing that I'll ring sky again tomorrow.
