Discussion topic: Internet not working
This message was authored by: Guyver92
WiFi is down - router is amber on WiFi - Sky app saying no connection issues
Re: Internet not working
@Guyver92
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
