Discussion topic: No wifi
This message was authored by: Oliver35
No wifi
Hi , I have no WiFi, have tested and it says there is no problem but I have restarted my WiFi hub several times and still no WiFi , orange light on voice .
Re: No wifi
@Oliver35
Use the below link to check to see if there are any outages nearby https://www.sky.com/servicechecker
