Discussion topic: No broadband
Message posted on 11 Jan 2025 10:55 AM
No broadband
Hi I've tested through online check and followed steps but no internet connection wifi or enet devices
Message posted on 11 Jan 2025 11:31 AM
Re: No broadband
@Phil171
Use the below link to check to see if there are any outages nearby https://www.sky.com/servicechecker
