1
This discussion topic has been answered Discussion topic: No wifi again!!
This message was authored by: christie289
No wifi again!!
No internet again! Help please
Re: No wifi again!!
@christie289
Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your ISP (Sky).
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
Re: No wifi again!!
@christie289
