1
This discussion topic has been answered Discussion topic: Not working
This message was authored by: Lexiwytch
Not working
Wifi has died. I've reset the router but it's not coming back online. Also, phone line hasn't worked since day 1
Re: Not working
@Lexiwytch
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
Re: Not working
@Lexiwytch
