Discussion topic: No lights on router
Message posted on 28 Jan 2025 01:16 AM
No lights on router
I have no lights on the white router and can't connect anything to the hub but checked service and it says everything is ok but it isn't working please help?
Message posted on 28 Jan 2025 03:56 AM
Re: No lights on router
@LadyK
The lines may be busier than usual due to the damage and disruption caused by Storms Éowyn and Herminia which will also impact any potential Openreach visit.
