Discussion topic: Internet says no connection but tests say it’s running perfectly
Message posted on 28 Jan 2025 12:56 AM
Hi,
my internet says no connection but my sky tests say fully connected with both broadband and WiFi please advise?
Message posted on 28 Jan 2025 01:10 AM
Re: Internet says no connection but tests say it’s running perfectly
I am also having the same issue
Message posted on 28 Jan 2025 01:25 AM
I'm the same here .. n.ireland user
Message posted on 28 Jan 2025 03:58 AM - last edited: 28 Jan 2025 03:59 AM
It coukd be maintenance taking place which happens overnight to minimise disruption but otherwise, if you haven’t done it already, use the below link to check to see if there are any outages nearby https://www.sky.com/servicechecker
The lines may be busier than usual due to the damage and disruption caused by Storms Éowyn and Herminia which will also impact any potential Openreach visit.
