Discussion topic: Hub not working
Message posted on 27 Jan 2025 10:02 PM
Hub not working
My sky hub has stopped working. I've unplugged everything and followed the steps suggested by sky but still not working
Message posted on 28 Jan 2025 03:55 AM
Re: Hub not working
@Louise8311
The lines may be busier than usual due to the damage and disruption caused by Storms Éowyn and Herminia which will also impact any Openreach visit.
