Discussion topic: No intrnet
Message posted on 29 Jan 2026 10:31 AM
No intrnet
No internet dispute sky checker saying are broadband is ok. This is the third day running we have had disruptions
Message posted on 29 Jan 2026 11:42 AM
Re: No intrnet
@Scouse-
With any broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
