Discussion topic: No broadband
Message posted on 29 Jan 2026 12:00 PM
No broadband
Power light green
internet light - nothing
wifi light green
voice - amber
Message posted on 29 Jan 2026 12:09 PM
Re: No broadband
This explains the lights on the hubs:
If your ONT shows a red light then have a read of this:
Try running this line test to see if it finds any faults:
Re: No broadband
Hi @Peter348
The internet light not being lit at all usually means no physical connection is being made. Have you checked all cables are connected properly on both ends?
