Discussion topic: No internet or wifi connection
This message was authored by: SaintsJo82
Re: Internet down.
They just updated mine saying check internet so rebooted and everything gollowed all steps on help and now saying they need an engineer to come to area im in WA9 area .
This message was authored by: Phil147
Re: No internet or wifi connection
WA10. Exactly the same. No Wi-Fi. Checker says it's ok. Comes back on for a few minutes then goes again
This message was authored by: Teebs92
Same here WA9 3
This message was authored by: CrazyOps
Re: Internet down.
Having issues here, Anonymous?
This message was authored by: Sellyselkirk
Re: Internet down.
All fixed 😊
Re: No internet
Post deleted. Outage is more widespread.
This message was authored by: DJQ
Has anyones came back on yet ??
This message was authored by: jkelly48
Hi I'm in St Helens and also have issues with broadband connectivity says I'm connected but I'm not
When running the status check do not rely on the result the My Sky app shows initially as that is the status when the check last ran automatically instead click through to run a new check that will give you the up to up to date information on known faults. If the issue is within the Openreach network Sky will nor necessarily be aware of the details including which lines are affected. Sky's phone lines are starting to open from 7am so customers can report the loss of service.
None of the above affects the work which should be going on to find and fix the fault which will be going on whatever the status pages say.
This message was authored by: Minyrawel
No internet for 48hrs. Not acceptable!
This message was authored by: Mollie04
No internet for over 24 hrs WA10. Thought it was my fault as not good at these things at my age. Reading your posts has confirmed it's not so feel better. 3.47 am and still no briadband.
This message was authored by: innes1957
No Broadband connection! Switched of router at wall and back on again, still nothing!!
No, over a week now and still no broadband. Anyone else with the same problem.
Re: Internet down.
Hi, did it just come on or did you do something ? Thanks
Hi Molly it just came back on but we did reset it quite a few times, I'm looking at going somewhere else can't even watch TV in bedroom the signal is so poor, it's ridiculous for the price we pay x
