16
This discussion topic has been answered Discussion topic: No internet connection
This message was authored by: Rebekah13
Sky hub is flashing green I've reset the router twice but still getting no Internet connection the sky app tells me my hub is offline.
Re: No internet connection
@Rebekah13
@Rebekah13
Avatar for Rebekah13
Its tells me everything looks good
This message was authored by: Rupert100
I've got exactly the same issue tonight, slow flashing green light on the router. No wifi on any devices, have rebooted router twice inc switch off at plug. . The service checker shows everything as ok. Can't find any way to report a fault direct to customer services.
@Rupert100
This message was authored by: Sammy57
I have the same issue
This message was authored by: JamieW84
Mines the same, in Somerset, don't know where you all are, green flashing light for over an hour and have reset the router, called sky and they close at 9pm, got through at 8:55pm to an automated message to tell me lines close at 9pm, Sky have the worst customer service, checker is **bleep** as says everything is fine.
Landline also didn't work so had to use my mobile but finally managed to get past the automated ai agent to a human agent who was really helpful. open reach booked to come tomorrow. I'm in Stockport but seems to be an in-home issue. Will add an update tomorrow after open reach visit.
This message was authored by: Kate+Roberts
The sky status is not truthful - second night in a row no internet
My issue was fixed overnight, appears to have been fixed remotely. Appears that the service checker  was wrong. What didn't help was now landline is VOIP that didn't work and finding a number to call required internet access and I live in a mobile signal blackspot which made the whole process more difficult.
This message was authored by: Help1978
I have a no internet connection to my sky for 2 days.. I have  followed all the guidance to to reset and nothing is working.
@Help1978
Have you followed the advice in the post marked as the answer? If you have you may need to contact Sky to report it.
This message was authored by: Smokeyno1
Hi , my internet is not working ive done reset and checked everything but its still not working
@Smokeyno1
In view of the time you’ve posted it’s worth explaining that any broadband issues between midnight and 7am could be essential overnight maintenance taking place. It is carried out at those times to minimise disruption and there is no advance warning provided. See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
Hopefully it’s back up and running before 7am. If it’s not, try restarting your hub or post back in this thread and we can try to offer additional advice.
