Discussion topic: Absalotly rubbish
This message was authored by: Karene2512
Absalotly rubbish
Since having fibre installed I have had nothin but problems
downloads don't happen and apps taking to long to open
Re: Absalotly rubbish
@Karene2512 run a simole speedtest with Fast.com on one of the devicescyou are having problems with. If as is likely the WiFi connection is slow it means you need to improve the WiFi in your home. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
