Discussion topic: No internet connection
Message posted on 30 Dec 2025 07:19 PM
We have no internet, the hub lights keep changing from off to 3 green 1 orange, to 1 red all others off. Service checker says all is fine with wifi and broadband. I've reset the hub numerous times. Not sure what else to do.
Message posted on 30 Dec 2025 07:20 PM
Re: No internet connection
@clair1981
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
Message posted on 30 Dec 2025 08:10 PM
@clair1981 Explain what you do for the reset off that sky Hub? Your light / lights explanation does not make any sense for that sky Hub!
Message posted on 30 Dec 2025 08:49 PM - last edited: 30 Dec 2025 08:50 PM
There's little point doing so: it cannot resolve an external fault. Once before and once after unplugging and replugging the physical connections is enough.
Message posted on 31 Dec 2025 11:10 AM
Theres a tiny little button on the back that says reset, troubleshooting instructions asked me to hold it down for 30 seconds
Message posted on 31 Dec 2025 11:11 AM
I was following the troubleshooting instructions. An engineer is coming out today as they think the hub has a fault
Message posted on 31 Dec 2025 11:50 AM
@clair1981 The reset guide also advises, watch the power LED at the same time while holding that reset button, once you see it all change state, couple seconds more and release at that point, if not followed that way the sky Hub just reboots itself with NO reset done!
Message posted on 31 Dec 2025 04:22 PM
Thanks 🙂
Engineer replaced the hub, so we are all good now
