Discussion topic: No internet connection
Message posted on 31 Dec 2025 04:06 PM
Internet is not working and has red light on
Message posted on 31 Dec 2025 04:25 PM
Re: No internet connection
@LJB7
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
