Discussion topic: No Internet i have power lights on hub power green Internet no light wifi green voice amber .
This message was authored by: corkboy59
Green light on power no light on Internet green light on WiFi and orange light on voice
Re: No Internet i have power lights on hub power green Internet no light wifi green voice amber .
@corkboy59
See further down about the hub lights…
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
