Discussion topic: Amber light on my sky broadband
Message posted on 30 Sep 2025 12:59 AM
Message posted on 30 Sep 2025 04:58 AM
Re: Amber light on my sky broadband
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back before 7.
If you still have broadband problems in the morning use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
