Discussion topic: No internet connection
Message posted on 29 Apr 2025 05:37 PM
There's a problem with the broadband. I've tried resetting but to no avail.
Message posted on 29 Apr 2025 05:40 PM
Re: No internet connection
There was no reply
Message posted on 29 Apr 2025 05:46 PM
@Danny631 wrote:
There was no reply
From who?
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
