Discussion topic: No internet connection
This message was authored by: RobBlanchard
Power and wifi lights are green.
internet light is off.
voice light is orange.
have reset the router power but made no difference.
This message was authored by: adamrahman
Re: No internet connection
same issue
This message was authored by: Angela1976
same as me
This message was authored by: Tiarad
Same problem
No help anywhere ,done all the usual stuff ,
Sky say no problems  clearly there is
At the time of night you've posted it could be overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's not back by 0700 use the below link to check to see if there are any problems or outages nearby
If there aren't any then try running the line test here https://www.sky.com/help/articles/broadband-diagnostic-start
Once completed, if it reports back that all is good click on 'broadband' to run an updated test.
If you get amber or red you need to follow the on-screen instructions.
If you're still having problems you may need to call Sky to report it. Dial 150 free from your Sky Talk landline (if it's still working).
This link providers information about the coloured lights on the various hubs https://www.sky.com/help/articles/hub-lights-explained-start
