Discussion topic: Wifi not working
Message posted on 18 Mar 2025 01:27 AM
Wifi not working
I am paying for WiFi and it's not working we rely on this for cameras for babies rooms this is not on. Please want this resolved.
Message posted on 18 Mar 2025 05:22 AM
Re: Wifi not working
@Phily26
If you’re not already aware this is a customer helps customer forum and you aren’t contacting Sky Customer Services.
At the time of night you've posted it could be overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's not back by 0700 use the below link to check to see if there are any problems or outages nearby
