Discussion topic: I have the new Sky Max hub but signal is still poor. My tv won't connect
This message was authored by: AliB00
Connection to the Sky max hub is poor and I was told this upgrade would work to connect my devices in the house!
Re: I have the new Sky Max hub but signal is still poor. My tv won't connect
@AliB00 the range of the Sky Max hub is no different than the other hubs but if you have bought the Sky WiFi Max package then Sky will send you a pod extender if you ask and supply up to a further 2 after an engineer has checked your netwirk.
