2
This discussion topic has been answered Discussion topic: No internet connection
This message was authored by: Karine
No internet connection, tried all of the trouble shooting and nothing has worked
Re: No internet connection
@Karine
Any Openreach visit that’s required is likely to be delayed due to the disruption from the recent storms.
@Karine
Avatar for Karine
Hi,
Thank you for this. I have tried each of these and nothing has worked. I have an engineer coming out to me on Wednesday now.
I appreciate your support.
Kind regards,
Karine
