Discussion topic: No broadband
This message was authored by: Stout1977
No broadband
I have had no broadband all weekend.
Re: No broadband
@Stout1977
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
