Discussion topic: No broadband
This message was authored by: DaveLeslie
No broadband
No internet connection to my house. Have sky glass so no tv either
Re: No broadband
@DaveLeslie
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
