Discussion topic: Wifi won’t connect on most rooms
This message was authored by: Jadecal
Both upstairs televisions won't connect to the WiFi and it won't connect anything at the back of the house. We only have a small 3 bedroom house and the only place the WiFi is working is the frontroom that the router is in
Re: Wifi won’t connect on most rooms
@Jadecal
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
