Discussion topic: No WiFi connection
This message was authored by: S-O-R
No WiFi connection
Appears to be an issue with the WiFi connection, broadband connection is ok
Re: No WiFi connection
@S-O-R
Briadband is what comes to your property and Wi-Fi is how it transmits in your home so try a reboot of your hub at the mains and if that doesn't work then try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
