Discussion topic: No broadband
Message posted on 20 May 2025 07:02 PM
No broadband
My broadband is not working and I have done all the things and it still isn't working
Message posted on 20 May 2025 07:06 PM
Re: No broadband
@Iain42
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Message posted on 04 Jun 2025 07:27 PM
WiFi not working
My wifi isn't working again
Message posted on 04 Jun 2025 07:32 PM
Re: WiFi not working
@Iain42
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If the advice in the first reply didnt fix things did you call Sky as suggested?
Message posted on 30 Jun 2025 09:31 PM
No WiFi
I have no wifi again why is this happening
Message posted on 30 Jun 2025 10:44 PM
