Discussion topic: No broadband
Message posted on 07 Jan 2025 05:29 PM
No broadband
Did all the tests and rebooted but still not working from Thursday 2nd January. It's affecting my work as work from home
Message posted on 07 Jan 2025 05:38 PM
Re: No broadband
@PC28CAM_
The first thing to do is check to see if there are any outages nearby via this link https://www.sky.com/servicechecker
Remember as Sky Broadband is a domestic service wfh brings no additional benefits in terms of repair times.
