Discussion topic: No broadband...
This message was authored by: Shakinsteve
No broadband...
No broadband since about 7.45pm
Sky app says no issues...but clearly there is...
Re: No broadband...
@Shakinsteve  Can you run through what lights you see on the router and what ones you don't from the link below.
Avatar for Shakinsteve
Re: No broadband...
Green Amber Green
Re: No broadband...
@Shakinsteve  Did you go through by clicking on your router which you have it will take you through what the possible problems can be.
This message was authored by: Kerry681
Re: No broadband...
I've had no internet connection most of the day DY9 area 😡
Re: No broadband...
Yes i have followed but still no broadband...so fed up with sky lack of service...
Thank for your help..
Re: No broadband...
@Shakinsteve  What did it say for you to do when you found out what the issue was and the next steps to take?
Re: No broadband...
They just said there's problem in area and engineer's are trying to fix it, but that's been nearly all day 🙄 & same answer everytime I check
Re: No broadband...
@Kerry681 area issues can take a while to fix and nobody can normally tell you how long it will take so sorry you will have to be patient. You wil be compensated if ther sevice is down fir more than 2 working days.
