Discussion topic: No broadband connection
This message was authored by: adamdavenport
My broadband is not working. However all tests says its fine
Re: No broadband connection
@adamdavenport
You can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Remember Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
Avatar for adamdavenport
hey sorry, i didnt give much detail i thought i was going through to chat, engineer is booked in. had a company called GNS laying new fibre cables, but apparently thats all they are doing, and not touching connections. however it went off while they were here. but will wait and see what engineer says
