Discussion topic: No broadband connection
This message was authored by: Ali131
I haven't had WiFi for over 24 hours. I have run all the checks using the website, and although it says there's a problem with my broadband, it then goes on to say service in area, HUB connection etc is OK. My phone it connected, but says 'connected without internet'. I've tuned off at the mains and back on...nothing! Any suggestions? I really need it back on today.
Thank you!
Re: No broadband connection
@Ali131
