Discussion topic: No broadband. Second time in 2 weeks the same problem
Message posted on 04 Mar 2026 08:59 AM
No broadband although SKY say there is no local problem. Need to be up and running
Message posted on 04 Mar 2026 09:22 AM
Re: No broadband. Second time in 2 weeks the same problem
@You may wish to check later then.
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to be displayed by the software test! This should determine if there's an identified fault affecting multiple households.
or look at the lights info below.
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
