Discussion topic: No WiFi
This message was authored by: SJ83
No WiFi
Why is there no wifi
Re: No WiFi
@SJ83
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
▪️I AM NOT A SKY EMPLOYEE ▪️
